Ana içeriğe geç
Lenovo Yoga 710-15ISK Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver. The location of the screws is encircled in the photo.
  2. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 2, 1 resimden 1.
    • Gently remove the back cover of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: adım 3, 2 resimden 1. Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the laptop.
  6. Lenovo Yoga 710-15ISK Motherboard Replacement, Fans: adım 6, 1 resimden 1.
    • Remove the four 1.5 mm screws from the fans with a Phillips #00 screwdriver.
  7. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 7, 1 resimden 1.
    • Unplug the wire connecting the fan to the motherboard by gently pulling the white head from the port.
  8. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 8, 2 resimden 1. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift both fans to remove them from the laptop.
  9. Lenovo Yoga 710-15ISK Motherboard Replacement, SSD: adım 9, 1 resimden 1.
    • Remove the sticker from the SSD to gain access to the screw underneath.
  10. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 10, 2 resimden 1. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the screw holding the SSD in place using a Phillips #0 screwdriver.
    • Gently pull on the plastic clip next to the screw until the stick is freed and bounces up.
  11. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 11, 1 resimden 1.
    • Slide the SSD out of the laptop.
  12. Lenovo Yoga 710-15ISK Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Remove seven 2 mm screws from the motherboard using a Phillips #0 screwdriver.
  13. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 13, 3 resimden 1. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 13, 3 resimden 2. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 13, 3 resimden 3.
    • Unplug four cables attached to the motherboard.
    • For the flat ribbon wires, lift the black tabs holding them in place before removing them.
  14. Lenovo Yoga 710-15ISK Motherboard Replacement: adım 14, 1 resimden 1.
    • Carefully lift out the motherboard to remove it from the laptop.
Sonuç
Annette Limoges
181 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 üyesi
UMASSD-SINCLAIRE-S22S7G1
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 36
Her zaman: 358
