Ana içeriğe geç
Lenovo Yoga 710-15ISK SSD Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-15ISK SSD Replacement, Back Cover: adım 1, 2 resimden 1. Lenovo Yoga 710-15ISK SSD Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver. The location of the screws is encircled in the photo.
  2. Lenovo Yoga 710-15ISK SSD Replacement: adım 2, 1 resimden 1.
    • Gently remove the back cover of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK SSD Replacement, SSD: adım 3, 1 resimden 1.
    • Remove the sticker from the SSD to gain access to the screw underneath.
  4. Lenovo Yoga 710-15ISK SSD Replacement: adım 4, 2 resimden 1. Lenovo Yoga 710-15ISK SSD Replacement: adım 4, 2 resimden 2.
    • Remove the screw holding the SSD in place using a Phillips #0 screwdriver.
    • Gently pull on the plastic clip next to the screw until the stick is freed and bounces up.
  5. Lenovo Yoga 710-15ISK SSD Replacement: adım 5, 1 resimden 1.
    • Slide the SSD out of the laptop.
Sonuç
Elisa Normand
423 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Sinclaire Fall 2021 UMass Dartmouth, Team 3-5, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S3G5
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 40
Her zaman: 549
