Giriş
This guide will show you how to remove the fingerprint reader.
Neye ihtiyacın var
Bu adımda kullanılan alet:JIS Driver Set$19.99
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
Pull the battery towards you until the wire is accessible.
gently tug and wiggle on the wire until it pops out.
Remove the battery.
Bu adımda kullanılan alet:Spudger$3.99
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Aiden,
How do I repair the power button on this model? It no longer clicks and I have to use a paper clip on the opposite side. Looks like I need to remove the motherboard to gain access
