Ana içeriğe geç
Lenovo Yoga 720-12IKB Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 720-12IKB Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Battery Replacement: adım 2, 1 resimden 1.
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Battery Replacement: adım 3, 2 resimden 1. Lenovo Yoga 720-12IKB Battery Replacement: adım 3, 2 resimden 2.
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Battery Replacement: adım 4, 2 resimden 1. Lenovo Yoga 720-12IKB Battery Replacement: adım 4, 2 resimden 2.
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Battery Replacement: adım 5, 1 resimden 1.
    • Finally remove the battery from the case.
Sonuç
Alex Escobar
778 İtibar
6 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Pee Spring 2022 Gateway, Team 1-4, Pee Spring 2022 üyesi
GCC-PEE-S22S1G4
3 Üyeler
Bir Yorum
I need to replace the battery in my Yoga 720-15IKB Laptop. This guide looks like it will work for me as well. Thanks.
Vaughn Berger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 38
Her zaman: 968
