Giriş
If you are experiencing a loose or dirty headphone jack on your laptop then you will have to replace the headphone jack on the Lenovo 720-12IKB
The headphone jack on the Lenovo 720-12IKB is necessary to listen to the audio through a headset.
Use caution when replacing components in your Laptop as you could damage other components.
Neye ihtiyacın var
The headphone jack can be found on the top right of the chassis.
Start by removing the 2.0 mm Phillips #00 screw.
