Ana içeriğe geç
Lenovo Yoga 720-15IKB Bottom Cover Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Start by flipping the device over so that you see the screws.
    • Remove the 7 T5 short screws.
    • Remove the 3 long T5 screws.
  2. Lenovo Yoga 720-15IKB Bottom Cover Replacement: adım 2, 2 resimden 1. Lenovo Yoga 720-15IKB Bottom Cover Replacement: adım 2, 2 resimden 2.
    • Starting at the left USB port use you opening tool to gently pry up the bottom case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop's edge as shown by the arrows.
    • Do NOT pry along the top side, or you will damage the casing. Stay with the arrows.
  3. Lenovo Yoga 720-15IKB Bottom Cover Replacement: adım 3, 1 resimden 1.
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the bottom case.
Sonuç
dkay
226 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 10
Son 30 gün: 16
Her zaman: 121
