Ana içeriğe geç
Lenovo Yoga 720-15IKB Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 720-15IKB Motherboard Replacement, Bottom Cover: adım 1, 3 resimden 1. Lenovo Yoga 720-15IKB Motherboard Replacement, Bottom Cover: adım 1, 3 resimden 2. Lenovo Yoga 720-15IKB Motherboard Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 2, 2 resimden 1. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Motherboard Replacement, Fan: adım 3, 2 resimden 1. Lenovo Yoga 720-15IKB Motherboard Replacement, Fan: adım 3, 2 resimden 2.
    • Remove the six 5.2mm Torx T5 screws holding the fan in place.
    • Remove the five 5.0mm Torx T5 screws holding the fan in place.
  4. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 4, 3 resimden 1. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 4, 3 resimden 2. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 4, 3 resimden 3.
    • Disconnect the two fan wire connectors.
    • Firmly pull the connector out horizontally away from the socket.
    • Carefully lift the fan up and out.
  5. Lenovo Yoga 720-15IKB Motherboard Replacement, Battery: adım 5, 2 resimden 1. Lenovo Yoga 720-15IKB Motherboard Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the four 4mm screws surrounding the battery with a Phillips #0 screwdriver.
    • Each is marked by "M2x5" with a small white arrow pointing to the screw itself.
  6. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 6, 2 resimden 1. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 6, 2 resimden 2.
    • Pull firmly on the battery connector to disconnect it.
  7. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 7, 1 resimden 1.
    • Lift the battery out of the case to remove it.
  8. Lenovo Yoga 720-15IKB Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Using the Phillips #000 screwdriver, remove the five screws.
  9. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 9, 2 resimden 1. Lenovo Yoga 720-15IKB Motherboard Replacement: adım 9, 2 resimden 2.
    • Disconnect the power outlet connector.
    • Disconnect the speaker wire connector.
    • Carefully lift the motherboard up and out of the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 45
Her zaman: 1,724
