Ana içeriğe geç
Lenovo Yoga 720-15IKB Speakers Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: adım 1, 3 resimden 1. Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: adım 1, 3 resimden 2. Lenovo Yoga 720-15IKB Speakers Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Speakers Replacement: adım 2, 2 resimden 1. Lenovo Yoga 720-15IKB Speakers Replacement: adım 2, 2 resimden 2.
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: adım 3, 3 resimden 1. Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: adım 3, 3 resimden 2. Lenovo Yoga 720-15IKB Speakers Replacement, Speakers: adım 3, 3 resimden 3.
    • Here are the speakers for this device.
    • Pull the right speaker straight up and remove it from the computer.
    • As you remove the speaker, make sure to also carefully pull the wire connected to the speaker out along with the speaker.
  4. Lenovo Yoga 720-15IKB Speakers Replacement: adım 4, 1 resimden 1.
    • Remove the left speaker similarly to how the right speaker was removed.
  5. Lenovo Yoga 720-15IKB Speakers Replacement: adım 5, 1 resimden 1.
    • Unplug the speaker by firmly pulling the wire out of the socket.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeremy Kostel
249 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G3, White Winter 2020 Cal Poly, Team S19-G3, White Winter 2020 üyesi
CPSU-WHITE-W20S19G3
4 Üyeler
25 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 450
