Ana içeriğe geç
Lenovo Yoga 730-13IKB Back Case Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: adım 1, 3 resimden 1. Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: adım 1, 3 resimden 2. Lenovo Yoga 730-13IKB Back Case Replacement, Back Case: adım 1, 3 resimden 3.
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Back Case Replacement: adım 2, 3 resimden 1. Lenovo Yoga 730-13IKB Back Case Replacement: adım 2, 3 resimden 2. Lenovo Yoga 730-13IKB Back Case Replacement: adım 2, 3 resimden 3.
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Back Case Replacement: adım 3, 1 resimden 1.
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
Sonuç
Colin Reay
848 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G1, White Winter 2020 Cal Poly, Team S1-G1, White Winter 2020 üyesi
CPSU-WHITE-W20S1G1
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 44
Her zaman: 2,250
