Ana içeriğe geç
Lenovo Yoga 730-13IKB Speaker Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 730-13IKB Speaker Replacement, Back Case: adım 1, 3 resimden 1. Lenovo Yoga 730-13IKB Speaker Replacement, Back Case: adım 1, 3 resimden 2. Lenovo Yoga 730-13IKB Speaker Replacement, Back Case: adım 1, 3 resimden 3.
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Speaker Replacement: adım 2, 3 resimden 1. Lenovo Yoga 730-13IKB Speaker Replacement: adım 2, 3 resimden 2. Lenovo Yoga 730-13IKB Speaker Replacement: adım 2, 3 resimden 3.
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Speaker Replacement, Battery: adım 4, 2 resimden 1. Lenovo Yoga 730-13IKB Speaker Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the four 3.5mm Phillips #0 screws securing the battery.
  5. Lenovo Yoga 730-13IKB Speaker Replacement: adım 5, 3 resimden 1. Lenovo Yoga 730-13IKB Speaker Replacement: adım 5, 3 resimden 2. Lenovo Yoga 730-13IKB Speaker Replacement: adım 5, 3 resimden 3.
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • The battery connector does not lock and requires light pressure to insert and remove. To reinstall the battery cable, hold onto the black housing and push it into the motherboard connector.
  6. Lenovo Yoga 730-13IKB Speaker Replacement: adım 6, 3 resimden 1. Lenovo Yoga 730-13IKB Speaker Replacement: adım 6, 3 resimden 2. Lenovo Yoga 730-13IKB Speaker Replacement: adım 6, 3 resimden 3.
    • Remove the battery by pulling up near the white label and lifting diagonally away from the laptop.
    • Consider using a plastic opening tool to gently pry up near the white label if the battery seems stuck.
    • To reinstall the battery, carefully align its mounting holes with the plastic pins on the laptop frame.
  7. Lenovo Yoga 730-13IKB Speaker Replacement, Speaker: adım 7, 2 resimden 1. Lenovo Yoga 730-13IKB Speaker Replacement, Speaker: adım 7, 2 resimden 2.
    • Lift the left speaker module straight off its screw-less mount.
    • Both speaker modules are mounted with rubber spacers instead of screws. Removal and installation is done by hand.
  8. Lenovo Yoga 730-13IKB Speaker Replacement: adım 8, 2 resimden 1. Lenovo Yoga 730-13IKB Speaker Replacement: adım 8, 2 resimden 2.
    • Pull the speaker wire out from the plastic hooks on the laptop frame.
    • Pay close attention to the wire routing when removing the speaker for successful reinstallation. The wire should be secure in the hooks but not overly tight.
  9. Lenovo Yoga 730-13IKB Speaker Replacement: adım 9, 3 resimden 1. Lenovo Yoga 730-13IKB Speaker Replacement: adım 9, 3 resimden 2. Lenovo Yoga 730-13IKB Speaker Replacement: adım 9, 3 resimden 3.
    • Hold the white speaker connector with a finger and a spudger. Pull straight back to disconnect the speaker cable.
    • Lift the right speaker module straight up from its mount.
    • The speaker connector does not lock but requires moderate force to disconnect.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ethan Wagner
531 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G1, White Winter 2020 Cal Poly, Team S1-G1, White Winter 2020 üyesi
CPSU-WHITE-W20S1G1
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 49
Her zaman: 2,354
