Ana içeriğe geç
Lenovo Yoga 910-13IKB Speakers Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 910-13IKB Speakers Replacement, Bottom Panel: adım 1, 2 resimden 1. Lenovo Yoga 910-13IKB Speakers Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB Speakers Replacement: adım 2, 1 resimden 1.
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery. The battery is the large black rectangle at the bottom of the area.
  3. Lenovo Yoga 910-13IKB Speakers Replacement: adım 3, 1 resimden 1.
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using the wedge device.
    • Remove the trackpad using the wedge device.
  4. Lenovo Yoga 910-13IKB Speakers Replacement: adım 4, 1 resimden 1.
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB Speakers Replacement: adım 5, 3 resimden 1. Lenovo Yoga 910-13IKB Speakers Replacement: adım 5, 3 resimden 2. Lenovo Yoga 910-13IKB Speakers Replacement: adım 5, 3 resimden 3.
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB Speakers Replacement: adım 6, 3 resimden 1. Lenovo Yoga 910-13IKB Speakers Replacement: adım 6, 3 resimden 2. Lenovo Yoga 910-13IKB Speakers Replacement: adım 6, 3 resimden 3.
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
  7. Lenovo Yoga 910-13IKB Speakers Replacement, Speakers: adım 7, 2 resimden 1. Lenovo Yoga 910-13IKB Speakers Replacement, Speakers: adım 7, 2 resimden 2.
    • Remove the four silver 3mm JIS #00 screws holding the speakers in place.
  8. Lenovo Yoga 910-13IKB Speakers Replacement: adım 8, 2 resimden 1. Lenovo Yoga 910-13IKB Speakers Replacement: adım 8, 2 resimden 2.
    • Lift up the speaker from the corner of the device.
    • Pull gently on the bundled cable connector at the top of the speaker.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
  9. Lenovo Yoga 910-13IKB Speakers Replacement: adım 9, 2 resimden 1. Lenovo Yoga 910-13IKB Speakers Replacement: adım 9, 2 resimden 2.
    • Repeat step three for the speaker on the opposite side of the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Connor Dilloughery
139 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G5, White Winter 2020 Cal Poly, Team S1-G5, White Winter 2020 üyesi
CPSU-WHITE-W20S1G5
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 33
Her zaman: 784
