Ana içeriğe geç
Lenovo Yoga 910-13IKB Trackpad Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 910-13IKB Trackpad Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo Yoga 910-13IKB Trackpad Replacement, Back Panel: adım 1, 2 resimden 2.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Trackpad Replacement, Battery: adım 2, 1 resimden 1.
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Trackpad Replacement: adım 3, 3 resimden 1. Lenovo Yoga 910-13IKB Trackpad Replacement: adım 3, 3 resimden 2. Lenovo Yoga 910-13IKB Trackpad Replacement: adım 3, 3 resimden 3.
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: adım 4, 3 resimden 1. Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: adım 4, 3 resimden 2. Lenovo Yoga 910-13IKB Trackpad Replacement, Trackpad: adım 4, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove all six screws holding the trackpad to the device.
    • Find the ribbon cable, the black bundle of wires attached to the trackpad, and lift the head of the ribbon cable towards you.
    • Carefully lift up the trackpad and remove it from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 18
Her zaman: 398
