Ana içeriğe geç
Lenovo Yoga 910-13IKB USB Ports Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 910-13IKB USB Ports Replacement, Bottom Panel: adım 1, 2 resimden 1. Lenovo Yoga 910-13IKB USB Ports Replacement, Bottom Panel: adım 1, 2 resimden 2.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 2, 1 resimden 1.
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery.
  3. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 3, 1 resimden 1.
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using a wedge device.
    • Remove the trackpad using a wedge device
  4. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 4, 1 resimden 1.
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 5, 3 resimden 1. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 5, 3 resimden 2. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 5, 3 resimden 3.
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 6, 3 resimden 1. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 6, 3 resimden 2. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 6, 3 resimden 3.
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
  7. Lenovo Yoga 910-13IKB USB Ports Replacement, Battery: adım 7, 1 resimden 1.
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  8. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 8, 3 resimden 1. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 8, 3 resimden 2. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 8, 3 resimden 3.
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  9. Lenovo Yoga 910-13IKB USB Ports Replacement, USB Ports: adım 9, 3 resimden 1. Lenovo Yoga 910-13IKB USB Ports Replacement, USB Ports: adım 9, 3 resimden 2. Lenovo Yoga 910-13IKB USB Ports Replacement, USB Ports: adım 9, 3 resimden 3.
    • Remove the five 3mm JIS #00 screws holding the array of ports in place.
  10. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 10, 1 resimden 1.
    • Lift up on the cover on top of the ribbon connector and gently pull the ribbon cable out.
  11. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 11, 1 resimden 1.
    • Lift up on the component and remove it.
  12. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 12, 1 resimden 1.
    • Repeat the same process on the opposite side, lifting up on the connector cover and pulling the ribbon cable out of its place.
  13. Lenovo Yoga 910-13IKB USB Ports Replacement: adım 13, 1 resimden 1.
    • Lift up on the set of ports and remove it from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Pablo Gonzalez
538 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G5, White Winter 2020 Cal Poly, Team S1-G5, White Winter 2020 üyesi
CPSU-WHITE-W20S1G5
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 4,118
