Giriş
If you need to replace the Wi-Fi card in your Lenovo Yoga 910-13IKB follow this guide.
Neye ihtiyacın var
Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
Remove the back panel from the device exposing the components.
Remove the single 1 mm screw at left of Wi-Fi card with a Phillips #0 screwdriver.
Bir başkası bu kılavuzu tamamladı.
