Ana içeriğe geç
Lenovo Yoga 910-13IKB Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: adım 1, 2 resimden 2.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Battery: adım 2, 1 resimden 1.
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: adım 3, 3 resimden 1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: adım 3, 3 resimden 2. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: adım 3, 3 resimden 3.
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 1 resimden 1.
    • Remove the single 1 mm screw at left of Wi-Fi card with a Phillips #0 screwdriver.
  5. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: adım 5, 2 resimden 1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: adım 5, 2 resimden 2.
    • Pull the Wi-Fi card out of the slot on the motherboard.
    • It is still connected to the coaxial cables so don't yank it out or those connections will break.
  6. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: adım 6, 3 resimden 1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: adım 6, 3 resimden 2. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: adım 6, 3 resimden 3.
    • Detach the white wire that is connected to the Wi-Fi card by applying gentle pressure.
    • Detach the black wire by applying gentle pressure.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 500
