Ana içeriğe geç
Lenovo Yoga 920-13IKB Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 920-13IKB Battery Replacement, Back Cover: adım 1, 2 resimden 1. Lenovo Yoga 920-13IKB Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Battery Replacement: adım 2, 3 resimden 1. Lenovo Yoga 920-13IKB Battery Replacement: adım 2, 3 resimden 2. Lenovo Yoga 920-13IKB Battery Replacement: adım 2, 3 resimden 3.
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Battery Replacement, Battery: adım 3, 3 resimden 1. Lenovo Yoga 920-13IKB Battery Replacement, Battery: adım 3, 3 resimden 2. Lenovo Yoga 920-13IKB Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Battery Replacement: adım 4, 2 resimden 1. Lenovo Yoga 920-13IKB Battery Replacement: adım 4, 2 resimden 2.
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Battery Replacement: adım 5, 1 resimden 1.
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery.
Sonuç
34 farklı kişi bu kılavuzu tamamladı.
Alyssa McCulloch
2.005 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S2G3
4 Üyeler
29 adet Kılavuz yazıldı
15Kılavuz Yorumları
What is the correct replacement battery for this device?
Stephen Prather - Yanıt
This is the battery that works in the 920: Lenovo Yoga 920 Battery - L16M4P60
Kyle Wiens -
Nice writeup!
Tim Averett - Yanıt
Simple, a real simple straight forward process with the right tools of course. Thanks
Daniel Smith - Yanıt
Thank you, was very easy replace battery using your guide!
Andrejs - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 53
Son 30 gün: 288
Her zaman: 27,089
