Ana içeriğe geç
Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: adım 1, 2 resimden 1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 2, 3 resimden 1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 2, 3 resimden 2. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 2, 3 resimden 3.
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: adım 3, 3 resimden 1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: adım 3, 3 resimden 2. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Battery: adım 3, 3 resimden 3.
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 4, 2 resimden 1. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 4, 2 resimden 2.
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 5, 1 resimden 1.
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 6, 1 resimden 1.
    • Remove the battery.
  7. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement, Fingerprint Sensor: adım 7, 1 resimden 1.
    • Remove the 3mm Phillips #00 Screw to loosen the sensor.
  8. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 8, 1 resimden 1.
    • Lift up the cover on the fingerprint sensor using the iFixit Opening Tool and remove the cover from the sensor.
  9. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 9, 1 resimden 1.
    • Flip up the cable connector tab using the iFixit Opening Tool to release the ribbon wire.
  10. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 10, 1 resimden 1.
    • Unplug the ribbon wire from the sensor to completely free the sensor.
  11. Lenovo Yoga 920-13IKB Fingerprint Sensor Replacement: adım 11, 1 resimden 1.
    • Lift the fingerprint sensor with the iFixit Opening Tool and remove it from the device.
Sonuç
Alyssa McCulloch
1.906 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S2G3
4 Üyeler
29 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 585
