Ana içeriğe geç
Lenovo Yoga 920-13IKB Screen Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 920-13IKB Screen Replacement, Screen: adım 1, 3 resimden 1. Lenovo Yoga 920-13IKB Screen Replacement, Screen: adım 1, 3 resimden 2. Lenovo Yoga 920-13IKB Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Rotate the device into tablet mode so the device’s screen is facing up.
  2. Lenovo Yoga 920-13IKB Screen Replacement: adım 2, 3 resimden 1. Lenovo Yoga 920-13IKB Screen Replacement: adım 2, 3 resimden 2. Lenovo Yoga 920-13IKB Screen Replacement: adım 2, 3 resimden 3.
    • Pry the metal cover up from the bottom of the screen with the iFixit Opening Tool to reveal the corners of the white adhesive strip.
    • Pull the metal cover off the device until it's completely free.
    • Clean off the old adhesive and straighten the metal cover when reassembling.
    • Use a new adhesive when reassembling.
    • Avoid bending the metal cover to prevent damage to the device.
    • If you’re really struggling, you may pry from the opposite side, but be careful not to damage the screen or metal cover.
  3. Lenovo Yoga 920-13IKB Screen Replacement: adım 3, 2 resimden 1. Lenovo Yoga 920-13IKB Screen Replacement: adım 3, 2 resimden 2.
    • Remove the eight 3mm Phillips #000 screws that were below the metal cover to loosen the screen.
  4. Lenovo Yoga 920-13IKB Screen Replacement: adım 4, 3 resimden 1. Lenovo Yoga 920-13IKB Screen Replacement: adım 4, 3 resimden 2. Lenovo Yoga 920-13IKB Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pull out the white adhesives using the iFixit Tweezers.
    • Roll the tape around the iFixit Tweezers to remove successfully.
  5. Lenovo Yoga 920-13IKB Screen Replacement: adım 5, 1 resimden 1.
    • Pry up the screen with the iFixit Opening Tool.
  6. Lenovo Yoga 920-13IKB Screen Replacement: adım 6, 2 resimden 1. Lenovo Yoga 920-13IKB Screen Replacement: adım 6, 2 resimden 2.
    • Lift the screen with your hands and place the the screen face down, keeping the device in the same location.
  7. Lenovo Yoga 920-13IKB Screen Replacement: adım 7, 1 resimden 1.
    • Flip up the black tab on the connector at the top of the screen with the iFixit Opening Tool.
  8. Lenovo Yoga 920-13IKB Screen Replacement: adım 8, 1 resimden 1.
    • Use the iFixit Tweezers to remove the ribbon cable from the connector.
  9. Lenovo Yoga 920-13IKB Screen Replacement: adım 9, 1 resimden 1.
    • Flip up the black tab on the smallest connector at the bottom of the screen with the iFixit Opening Tool.
  10. Lenovo Yoga 920-13IKB Screen Replacement: adım 10, 1 resimden 1.
  11. Lenovo Yoga 920-13IKB Screen Replacement: adım 11, 1 resimden 1.
    • Flip up the thick black cable at the bottom of the screen with your thumb.
    • Use the iFixit Opening Tool to lift up the brass tab to free up the cable.
  12. Lenovo Yoga 920-13IKB Screen Replacement: adım 12, 1 resimden 1.
    • Remove the ribbon cable from the connector to detach the screen from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alyssa McCulloch
2.005 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S2G3
4 Üyeler
29 adet Kılavuz yazıldı
5Kılavuz Yorumları
Does this also appy to the Yoga 910-13IBK?
Tony Salazar - Yanıt
Alyssa, I am about to tackle this job to replace a cracked screen - I greatly appreciate your guide. In step 2 you recommend using new adhesive. What adhesive is recommended exactly?
Bradley Buege - Yanıt
See this youtube video from Lenovo on LCD tape, how to find what kind, how to remove it, and how to reapply it.
https://www.youtube.com/watch?v=EeUM312_...
Robert -
You missed the camera transfer step. I completed the screen replacement only to find no camera for Zoom. Then realized the this procedure didn’t cover the camera transfer.
ddurbin1 - Yanıt
Ok, 15 minutes to complete this is ridiculous. A seasoned person couldn't do this in 15 minutes, especially when removing and replacing adhesive, etc. That must be a typo.
Syber Geek - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 73
Her zaman: 6,081
