Ana içeriğe geç
Lenovo Yoga 920-13IKB USB - C Port Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 920-13IKB USB - C Port Replacement, Back Cover: adım 1, 2 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 2, 3 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 2, 3 resimden 2. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 2, 3 resimden 3.
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB USB - C Port Replacement, Motherboard: adım 3, 2 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement, Motherboard: adım 3, 2 resimden 2.
    • Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
  4. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 4, 3 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 4, 3 resimden 2. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 4, 3 resimden 3.
    • Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
  5. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 5, 2 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 5, 2 resimden 2.
    • Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
  6. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 6, 2 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 6, 2 resimden 2.
    • Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
  7. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 7, 2 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 7, 2 resimden 2.
    • Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
  8. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 8, 3 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 8, 3 resimden 2. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 8, 3 resimden 3.
    • Lift the motherboard up parallel to the hinge of the device.
    • Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
    • Avoid pulling the motherboard all the way out until the green AC card is disconnected.
  9. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 9, 3 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 9, 3 resimden 2. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 9, 3 resimden 3.
    • Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
  10. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 10, 1 resimden 1.
    • Flip the motherboard over to access the back side.
  11. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 11, 3 resimden 1. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 11, 3 resimden 2. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 11, 3 resimden 3.
    • Remove four 3mm JIS #00 screws with the screwdriver.
    • Remove one 3mm Phillips #00 screw with the screwdriver.
    • The screws stay attached to the speaker when removed from the motherboard.
  12. Lenovo Yoga 920-13IKB USB - C Port Replacement: adım 12, 1 resimden 1.
    • Separate the fans from the motherboard to isolate it for replacement.
  13. Lenovo Yoga 920-13IKB USB - C Port Replacement, USB - C Port: adım 13, 1 resimden 1.
    • Replace the motherboard to replace the USB-C ports.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alyssa McCulloch
1.906 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S2G3
4 Üyeler
29 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 63
Her zaman: 6,111
