Ana içeriğe geç
Lenovo Yoga 920-13IKB USB 3.0 Port Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, Back Cover: adım 1, 2 resimden 1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, Back Cover: adım 1, 2 resimden 2.
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 2, 3 resimden 1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 2, 3 resimden 2. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 2, 3 resimden 3.
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, USB 3.0 Port: adım 3, 2 resimden 1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, USB 3.0 Port: adım 3, 2 resimden 2.
    • Disconnect the red and black wire connected to the speaker using the iFixit Tweezers.
  4. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 4, 1 resimden 1.
    • Lift up the black tab on the flat cable connector with the iFixit Opening Tool.
  5. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 5, 3 resimden 1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 5, 3 resimden 2. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 5, 3 resimden 3.
    • Flip up the tab using the iFixit Tweezers to release the flat cable.
  6. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 6, 2 resimden 1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 6, 2 resimden 2.
    • Undo the two 3mm Phillips #00 screws to loosen the USB 3.0 board.
  7. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 7, 3 resimden 1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 7, 3 resimden 2. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: adım 7, 3 resimden 3.
    • Remove the USB 3.0 Board from the device using the iFixit Opening Tool.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alyssa McCulloch
1.906 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G3, White Winter 2019 Cal Poly, Team S2-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S2G3
4 Üyeler
29 adet Kılavuz yazıldı
Bir Yorum
Just wanted to say thank you to Alyssa and the others who contributed to this.
I just used your guide to fix a problem with my Yoga constantly entering and waking (repeatedly, seconds apart) from connected sleep mode. Infuriating. It was accompanied by the USB connect/disconnect sound as well.
Using the Event Viewer I managed to find out it was entering sleep mode in response to the power button (which I wasn’t pressing). So, I used your guide to disconnect and reconnect the USB board and it has resolved my issue.
iFixIt gained some tools income, you gained some more reputation points, and I gained a laptop that’s behaving itself now!
Now, what else can I break? ;o)
Sean Puffett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 2,033
