Ana içeriğe geç
Lenovo Yoga C930-13IKB Back Cover Replacement
Neye ihtiyacın var
  1. Lenovo Yoga C930-13IKB Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Back Cover Replacement: adım 2, 2 resimden 1. Lenovo Yoga C930-13IKB Back Cover Replacement: adım 2, 2 resimden 2.
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Back Cover Replacement: adım 3, 2 resimden 1. Lenovo Yoga C930-13IKB Back Cover Replacement: adım 3, 2 resimden 2.
    • Carefully lift the cover off with your hands.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hanna Lazkani
824 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 üyesi
CPSU-WHITE-W20S19G5
4 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
On mine, not T5 but T4. Also screw holding the chip in is philips 000.
Jim Steele - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 53
Her zaman: 3,279
