Ana içeriğe geç
Lenovo Yoga C930-13IKB SSD Replacement
Neye ihtiyacın var
  1. Lenovo Yoga C930-13IKB SSD Replacement, Back Cover: adım 1, 1 resimden 1.
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB SSD Replacement: adım 2, 2 resimden 1. Lenovo Yoga C930-13IKB SSD Replacement: adım 2, 2 resimden 2.
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB SSD Replacement: adım 3, 2 resimden 1. Lenovo Yoga C930-13IKB SSD Replacement: adım 3, 2 resimden 2.
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB SSD Replacement, SSD: adım 4, 1 resimden 1.
    • Remove the screw ( 2 mm with a 5 mm head) that connect the SSD to the motherboard using a Phillips #00 screwdriver.
  5. Lenovo Yoga C930-13IKB SSD Replacement: adım 5, 1 resimden 1.
    • Pinch the left side of the SSD card.
    • Pull gently to the left, horizontal to the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hanna Lazkani
788 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 üyesi
CPSU-WHITE-W20S19G5
4 Üyeler
16 adet Kılavuz yazıldı
3 Yorum
I need to remove the stripped screw on the SSDs non-slot-end because Lenovo tightened it down with a military grade drill. To replace, it wasn’t mentioned which size screw was there.
John Tullos - Yanıt
Ty for the info but I'm looking to get windows installed onto the blank new hard drive so I can actually run and use it, lol! Unfortunately, the "automatic" registration process didn't work and my product key isn't to be found. In fact, my Microsoft account doesn't even have it registered as a device. But it does have it as a device I loaded apps from the Play Store though. So, there's proof it existed. Anywho, I'm stuck trying to get Windows on it before I re-install the hard drive. Any ideas are more than welcome! Thanks, M.H.
Mac Daditink - Yanıt
Good guide. I took the following steps and it went quickly and smoothly. Less than an hour start to finish:
1. I purchased a Samsung 980 (not Pro, but should also work).
2. Disabled bitlocker on my old SSD. I also backed up the key for future ref.
3. Downloaded and installed the Samsung SSD Magician and migration tools.
4. Put the new SSD into an external enclosure ($18 on Amazon).
5. Ran the migration software and copied my windows 11 to the new SSD.
6. Shutdown the laptop and swapped the SSDs.
7. Rebooted into windows.
8. Ran the Samsung Magician software and updated the SSD firmware.
9. Done and perfect.
Thomas Harding - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 69
Her zaman: 5,155
