Ana içeriğe geç
Lenovo Yoga Tab 3 10 Wifi Module Replacement
Neye ihtiyacın var
  1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Back Cover: adım 1, 1 resimden 1.
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 2, 3 resimden 1. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 2, 3 resimden 2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 2, 3 resimden 3.
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 3, 3 resimden 1. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 3, 3 resimden 2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 3, 3 resimden 3.
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: adım 4, 2 resimden 1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: adım 4, 2 resimden 2.
    • Use the nylon spudger to gently lift the foil cover of the wifi model.
  5. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to gently lift the gold tape located above the copper foil.
  6. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 6, 1 resimden 1.
    • Use the plastic spudger to disconnect the wifi module connector from the motherboard.
  7. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 7, 2 resimden 1. Lenovo Yoga Tab 3 10 Wifi Module Replacement: adım 7, 2 resimden 2.
    • Carefully lift the wifi module from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Phanudej
1.190 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Sullivan Spring 2017 USF Tampa, Team S3-G2, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G2
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
where can i buy this type of module?
rebeca rackolavsci - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 3,703
