Ana içeriğe geç
Lenovo Yoga Tab 3 8 Camera Replacement
Neye ihtiyacın var
  1. Lenovo Yoga Tab 3 8 Camera Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo Yoga Tab 3 8 Camera Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo Yoga Tab 3 8 Camera Replacement, Back Cover: adım 1, 3 resimden 3.
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Camera Replacement: adım 2, 1 resimden 1.
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Camera Replacement: adım 3, 3 resimden 1. Lenovo Yoga Tab 3 8 Camera Replacement: adım 3, 3 resimden 2. Lenovo Yoga Tab 3 8 Camera Replacement: adım 3, 3 resimden 3.
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Camera Replacement, Hinge: adım 4, 3 resimden 1. Lenovo Yoga Tab 3 8 Camera Replacement, Hinge: adım 4, 3 resimden 2. Lenovo Yoga Tab 3 8 Camera Replacement, Hinge: adım 4, 3 resimden 3.
    • With the tablet oriented screen side down and hinge opposite of you, locate the black plastic piece on the top right.
    • Remove the upper 4mm and lower 3mm screws with a PH00 screwdriver.
  5. Lenovo Yoga Tab 3 8 Camera Replacement: adım 5, 2 resimden 1. Lenovo Yoga Tab 3 8 Camera Replacement: adım 5, 2 resimden 2.
    • Position the kickstand to an almost closed position. Carefully move the plastic block aside and pry the metal lock out with a metal spudger.
    • Be careful not to pull off the wires connecting the plastic block.
    • The lock may be difficult to remove so you may need to apply more pressure to release the lock.
  6. Lenovo Yoga Tab 3 8 Camera Replacement: adım 6, 3 resimden 1. Lenovo Yoga Tab 3 8 Camera Replacement: adım 6, 3 resimden 2. Lenovo Yoga Tab 3 8 Camera Replacement: adım 6, 3 resimden 3.
    • At the opposite end of the hinge, locate the silver metal bracket over the wires coming from the end of the hinge. Remove the two 3mm screws with a PH00 screwdriver. Lift the bracket off with your fingers.
    • Removing the bracket will expose two silver connectors at the ends of the wires coming from the end of the hinge. Use tweezers to carefully lift off the two silver connectors.
    • Locate the smaller metal wire bracket guiding the wires coming from the end of the hinge. Remove the single black 2mm screw with a PH00 screwdriver. Lift the bracket off with your fingers.
  7. Lenovo Yoga Tab 3 8 Camera Replacement: adım 7, 2 resimden 1. Lenovo Yoga Tab 3 8 Camera Replacement: adım 7, 2 resimden 2.
    • Begin removing the entire hinge assembly by lifting it out, starting at the end where the lock is located. Carefully feed the wires through the hinge mount with your fingers as you pull the hinge assembly free.
  8. Lenovo Yoga Tab 3 8 Camera Replacement, Camera: adım 8, 1 resimden 1.
    • Locate the silver camera mounting bracket between the power button and the camera housing. Remove the two 3mm screws on the camera mounting bracket using a PH00 screwdriver.
  9. Lenovo Yoga Tab 3 8 Camera Replacement: adım 9, 2 resimden 1. Lenovo Yoga Tab 3 8 Camera Replacement: adım 9, 2 resimden 2.
    • The camera housing is held in place by a pin in the center of the grey hinge mount. Push and hold in the pin with the pointy end of a spudger while you lift the camera assembly out.
  10. Lenovo Yoga Tab 3 8 Camera Replacement: adım 10, 1 resimden 1.
    • Remove the three 5mm screws holding together the camera housing using a PH00 screwdriver.
  11. Lenovo Yoga Tab 3 8 Camera Replacement: adım 11, 2 resimden 1. Lenovo Yoga Tab 3 8 Camera Replacement: adım 11, 2 resimden 2.
    • Separate the camera from the housing by pulling it apart with your fingers.
Sonuç
Nicklaus Krems
1.049 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G2, Eyestone Fall 2017 USF Tampa, Team S16-G2, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S16G2
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
These are the best instructions to be found anywhere particularly the close up photographs are very helpful,Thank you.
Ste - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 1,055
