Ana içeriğe geç
Lenovo Yoga Tab 3 8 Wifi Module Replacement
Neye ihtiyacın var
  1. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Back Cover: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Open the kickstand by pressing the release button in the center.
    • Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
  2. Lenovo Yoga Tab 3 8 Wifi Module Replacement: adım 2, 1 resimden 1.
    • Remove the three 2mm screws under the kickstand with a PH00 screwdriver.
    • The third 2mm screw to the right may have an S sticker covering it which you can scrape off.
  3. Lenovo Yoga Tab 3 8 Wifi Module Replacement: adım 3, 3 resimden 1. Lenovo Yoga Tab 3 8 Wifi Module Replacement: adım 3, 3 resimden 2. Lenovo Yoga Tab 3 8 Wifi Module Replacement: adım 3, 3 resimden 3.
    • Starting along the edge opposite of the hinge, insert a plastic opening tool between the screen and the backing to begin separating the small clips holding the backing on.
    • Work along the edge and then up the sides, separating the clips with the plastic opening tool.
    • There is adhesive underneath the slot for the SD card so you will need to slowly apply some force to break the adhesive.
    • As the back is separated from the device, be careful to not lose the power button. It may come loose and fall out.
  4. Lenovo Yoga Tab 3 8 Wifi Module Replacement, Wifi Module: adım 4, 1 resimden 1.
    • Locate the WiFi module connection on the motherboard by following the grey wire along the bottom. Use a spudger to gently pry it off.
  5. Lenovo Yoga Tab 3 8 Wifi Module Replacement: adım 5, 2 resimden 1. Lenovo Yoga Tab 3 8 Wifi Module Replacement: adım 5, 2 resimden 2.
    Satın Al
    • Locate the copper foil holding down the WiFi module near where the grey wire connects. Use tweezers to carefully lift up and separate the copper foil.
  6. Lenovo Yoga Tab 3 8 Wifi Module Replacement: adım 6, 1 resimden 1.
    • Remove the three 2mm screws holding the wifi module to the device using a PH00 screwdriver.
  7. Lenovo Yoga Tab 3 8 Wifi Module Replacement: adım 7, 2 resimden 1. Lenovo Yoga Tab 3 8 Wifi Module Replacement: adım 7, 2 resimden 2.
    • Remove the grey wire from the channel holding it by gently lifting it up with your fingers.
    • Lift the wifi module out of the device with your fingers.
Sonuç
Nicklaus Krems
1.061 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G2, Eyestone Fall 2017 USF Tampa, Team S16-G2, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S16G2
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 1,791
