Ana içeriğe geç
Lenovo Yoga Tablet 2 830-F Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga Tablet 2 830-F Battery Replacement, Battery: adım 1, 2 resimden 1. Lenovo Yoga Tablet 2 830-F Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove two 3mm screws on the back of the device with a Phillips #00 bit.
    • Remove the single 2mm screw with a Phillips #00 bit.
    • Using the blue opening tool or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 2, 3 resimden 1. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 2, 3 resimden 2. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 2, 3 resimden 3.
    • Remove the six 3mm screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the three 3mm screws on the back of the secondary board with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Remove the ZIF connectors connecting the boards to the other electrical components
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 3, 3 resimden 1. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 3, 3 resimden 2. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 3, 3 resimden 3.
    • Remove the three 2mm screws on the back of the left speaker module with the Phillips Screwdriver #00 bit.
    • Remove the three 2mm screws on the back of the right speaker module with the Phillips Screwdriver #00 bit.
    • Gently remove both the left and right speaker modules.
  4. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 4, 2 resimden 1. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 4, 2 resimden 2.
    • Using the blue opening tool or spudger, pry the battery compartment off of the high located on the right hand side of the back.
    • This may require a decent amount of force to accomplish. If you feel like the white plastic holder will break, try using the spudger at a different angle.
    • Do not attempt to use the spudger on the right hand side of the device. It must be done on the left side.
  5. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 5, 3 resimden 1. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 5, 3 resimden 2. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove this metallic sticker with your fingernail to expose the screw underneath.
    • Remove the 3mm screw under the sticker with the Phillips Screwdriver #00 bit.
    • Using the tweezers, pull off the black clip that secures the battery compartment. This may require some force.
  6. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 6, 3 resimden 1. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 6, 3 resimden 2. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 6, 3 resimden 3.
    • Remove the hinge clip from one side of the battery compartment. Use the spudger tool if necessary.
    • The battery should be able to slide from the compartment.
  7. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 7, 2 resimden 1. Lenovo Yoga Tablet 2 830-F Battery Replacement: adım 7, 2 resimden 2.
    • Replace the old battery with the new battery
    • Be careful not to damage the ribbon cable on the new battery when inserting it into the compartment and reassembling the device.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Charles Rhode
612 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G4, Nance Fall 2017 USF Tampa, Team S2-G4, Nance Fall 2017 üyesi
USFT-NANCE-F17S2G4
3 Üyeler
13 adet Kılavuz yazıldı
6Kılavuz Yorumları
hi
where i can find batter, of battery cable
Humaid Al Siyabi - Yanıt
Excuse me, where can i get the battery if it is not for sale?
Joe Harry - Yanıt
Bought one off eBay: Replace Lenovo L14C3K31 L14D3K31 Battery For Yoga Tablet 2 1050F 1051F YT2-830
Rusty Travelboy Rob - Yanıt
Are you effin kidding me? All of this just to replace a battery?
Sf Chick - Yanıt
Sorry to tell you :
prying the battery compartment off with a spudger is the wrong disassembly move and you will very likely damage the fragile construction.
The correct way to go is to remove the speaker modules as shown and then pry / pull out the metal hinge clip on the headphone side. Once it´s out, the battery compartment can be swivelled out on that side with great ease. Assembly later works a treat. No damage done.
handyandy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 145
Her zaman: 24,819
