Ana içeriğe geç
Lenovo Yoga Tablet 2 830-F Camera Replacement
Neye ihtiyacın var
  1. Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: adım 1, 2 resimden 1. Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: adım 1, 2 resimden 2.
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Camera Replacement: adım 2, 3 resimden 1. Lenovo Yoga Tablet 2 830-F Camera Replacement: adım 2, 3 resimden 2. Lenovo Yoga Tablet 2 830-F Camera Replacement: adım 2, 3 resimden 3.
    • Using the Phillips Screwdriver #00 bit remove the 6 screws.
    • Using the Phillips Screwdriver #00 bit remove the 3 screws.
    • After removing all the screws, disconnect the ribbon cables.
    • Disconnect the ZIF connectors.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Camera Replacement: adım 3, 3 resimden 1. Lenovo Yoga Tablet 2 830-F Camera Replacement: adım 3, 3 resimden 2. Lenovo Yoga Tablet 2 830-F Camera Replacement: adım 3, 3 resimden 3.
    • After removing the motherboard and antennas the camera module is located on the right as marked in red.
    • Remove the three 2mm screws holding the module in place with the Phillips Screwdriver #00 bit.
    • The camera module is also held in place with adhesive so gently remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mario Gjyli
449 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G4, Nance Fall 2017 USF Tampa, Team S2-G4, Nance Fall 2017 üyesi
USFT-NANCE-F17S2G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 682
