Ana içeriğe geç
Lenovo Z70-80 Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Z70-80 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Lenovo Z70-80 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Use your fingers two push both latches away from each other to release the battery.
    • Pull the battery out.
  2. Lenovo Z70-80 Motherboard Replacement, Back Panel: adım 2, 3 resimden 1. Lenovo Z70-80 Motherboard Replacement, Back Panel: adım 2, 3 resimden 2. Lenovo Z70-80 Motherboard Replacement, Back Panel: adım 2, 3 resimden 3.
    • Remove the two Phillips #0 screws from the bottom panel.
    • Slide the panel down slightly, and then lift to pull it off.
  3. Lenovo Z70-80 Motherboard Replacement, Optical Drive: adım 3, 3 resimden 1. Lenovo Z70-80 Motherboard Replacement, Optical Drive: adım 3, 3 resimden 2. Lenovo Z70-80 Motherboard Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the single 3mm Phillips #0 screw from the optical drive.
    • Pull the optical drive out of the side.
  4. Lenovo Z70-80 Motherboard Replacement, Electric Fan: adım 4, 3 resimden 1. Lenovo Z70-80 Motherboard Replacement, Electric Fan: adım 4, 3 resimden 2. Lenovo Z70-80 Motherboard Replacement, Electric Fan: adım 4, 3 resimden 3.
    • Remove the three 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard by pulling up on the plug.
  5. Lenovo Z70-80 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove all the 17 7mm Phillips #0 screws.
    • A sticker covers this screw. Remove this sticker to remove the screw.
    • Remove the back cover.
  6. Lenovo Z70-80 Motherboard Replacement: adım 6, 3 resimden 1. Lenovo Z70-80 Motherboard Replacement: adım 6, 3 resimden 2. Lenovo Z70-80 Motherboard Replacement: adım 6, 3 resimden 3.
    • Pry the edges of the keyboard upwards using a spudger.
    • A cable with a ZIF connector is attached to the bottom of the keyboard. Flip the small black tab on the connector for safe removal.
    • Remove the five 3mm Phillips #0 screws.
  7. Lenovo Z70-80 Motherboard Replacement: adım 7, 3 resimden 1. Lenovo Z70-80 Motherboard Replacement: adım 7, 3 resimden 2. Lenovo Z70-80 Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove all the ribbon cables and connectors from the front and back of the laptop.
    • Remember to flip the small black tabs on ZIF connectors for safe removal.
  8. Lenovo Z70-80 Motherboard Replacement: adım 8, 2 resimden 1. Lenovo Z70-80 Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the 3mm screw and carefully pull out the cables from the hooks holding them in place.
  9. Lenovo Z70-80 Motherboard Replacement: adım 9, 2 resimden 1. Lenovo Z70-80 Motherboard Replacement: adım 9, 2 resimden 2.
    • Use a spudger at the edges of the laptop cover to carefully pry upwards, removing the cover.
  10. Lenovo Z70-80 Motherboard Replacement: adım 10, 3 resimden 1. Lenovo Z70-80 Motherboard Replacement: adım 10, 3 resimden 2. Lenovo Z70-80 Motherboard Replacement: adım 10, 3 resimden 3.
    • Unplug the two black cables from the motherboard.
    • Remove the three 3mm screws from the motherboard.
    • Remove the motherboard.
    • Pick up the motherboard carefully by the edges.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Eduardo Delgado
412 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team S1-G4, Johnson Spring 2018 Gateway, Team S1-G4, Johnson Spring 2018 üyesi
GCC-JOHNSON-S18S1G4
2 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 3,974
