Ana içeriğe geç
Lenovo Z70-80 Optical Drive Replacement
Neye ihtiyacın var
  1. Lenovo Z70-80 Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Lenovo Z70-80 Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Use your fingers two push both latches away from each other to release the battery.
    • Pull the battery out.
  2. Lenovo Z70-80 Optical Drive Replacement, Back Panel: adım 2, 3 resimden 1. Lenovo Z70-80 Optical Drive Replacement, Back Panel: adım 2, 3 resimden 2. Lenovo Z70-80 Optical Drive Replacement, Back Panel: adım 2, 3 resimden 3.
    • Remove the two Phillips #0 screws from the bottom panel.
    • Slide the panel down slightly, and then lift to pull it off.
  3. Lenovo Z70-80 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 1. Lenovo Z70-80 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 2. Lenovo Z70-80 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the single 3mm Phillips #0 screw from the optical drive.
    • Pull the optical drive out of the side.
Sonuç
Eduardo Delgado
412 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team S1-G4, Johnson Spring 2018 Gateway, Team S1-G4, Johnson Spring 2018 üyesi
GCC-JOHNSON-S18S1G4
2 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 899
