Ana içeriğe geç
Lenovo bluetooth mouse N6901A disassembly
Neye ihtiyacın var
  1. Lenovo bluetooth mouse N6901A disassembly, Mouse: adım 1, 1 resimden 1.
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. Lenovo bluetooth mouse N6901A disassembly: adım 2, 2 resimden 1. Lenovo bluetooth mouse N6901A disassembly: adım 2, 2 resimden 2.
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Lenovo bluetooth mouse N6901A disassembly: adım 3, 2 resimden 1. Lenovo bluetooth mouse N6901A disassembly: adım 3, 2 resimden 2.
    • At this point, you have separated the mouse cover
  4. Lenovo bluetooth mouse N6901A disassembly: adım 4, 1 resimden 1.
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  5. Lenovo bluetooth mouse N6901A disassembly: adım 5, 2 resimden 1. Lenovo bluetooth mouse N6901A disassembly: adım 5, 2 resimden 2.
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Shinn Chyang Chen
3.034 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 43
Son 30 gün: 255
Her zaman: 6,175
