Ana içeriğe geç
Lens Replacement
Neye ihtiyacın var
    1. Lens Replacement, Lens: adım 1, 3 resimden 1. Lens Replacement, Lens: adım 1, 3 resimden 2. Lens Replacement, Lens: adım 1, 3 resimden 3.
      • Step 1. Remove: Remove the indicated screws from the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Lens Replacement: adım 2, 3 resimden 1. Lens Replacement: adım 2, 3 resimden 2. Lens Replacement: adım 2, 3 resimden 3.
      • Step 2. Remove all the screws: Keep all the screws and disconnect the cables carefully.
      • Step 3. Lift: After removing all the cables, lift up and flip over the PCB.
      FixBot'a Sor
      Yorum Ekle
    3. Lens Replacement: adım 3, 2 resimden 1. Lens Replacement: adım 3, 2 resimden 2.
      • Step 4. Remove: Remove marked screws on top and around the lent.
      • **Remove all the parts, be aware that there are a lot of screws and keep count them a long the way of the dissambley **
      FixBot'a Sor
      Yorum Ekle
    4. Lens Replacement: adım 4, 2 resimden 1. Lens Replacement: adım 4, 2 resimden 2.
      • Step 5. Carefully remove as much of the glue as possible before proceeding to the next step.
      • Step 6. Remove the marked focus spacers.
      • Place a bead of silicone adhesive on each side of the ir filter to fix it in position and allow to cure.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Marina Bayardo
251 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 52
Her zaman: 1,975
