Ana içeriğe geç
Levoit Core 300-RAC Control Board Replacement
Neye ihtiyacın var
    1. Levoit Core 300-RAC Control Board Replacement, Control Board: adım 1, 3 resimden 1. Levoit Core 300-RAC Control Board Replacement, Control Board: adım 1, 3 resimden 2. Levoit Core 300-RAC Control Board Replacement, Control Board: adım 1, 3 resimden 3.
      • Make sure the device is turned off and unplugged before disassembling it.
      • Insert the Jimmy between the gray grille cover and the top of the device.
      • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
      • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
      • Remove the grille cover gently as it is connected by a ribbon cable.
      • Be careful not to put too much strain on the ribbon cable as it may break.
      FixBot'a Sor
      Yorum Ekle
    2. Levoit Core 300-RAC Control Board Replacement: adım 2, 3 resimden 1. Levoit Core 300-RAC Control Board Replacement: adım 2, 3 resimden 2. Levoit Core 300-RAC Control Board Replacement: adım 2, 3 resimden 3.
      • Squeeze the tab on the connector to release the bundled cable from the control board.
      • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
      FixBot'a Sor
      Yorum Ekle
    3. Levoit Core 300-RAC Control Board Replacement: adım 3, 2 resimden 1. Levoit Core 300-RAC Control Board Replacement: adım 3, 2 resimden 2.
      • Gently bend the gray plastic cover to release the control board.
      • There are several hard tabs holding the control board in place.
      FixBot'a Sor
      Yorum Ekle
    4. Levoit Core 300-RAC Control Board Replacement: adım 4, 3 resimden 1. Levoit Core 300-RAC Control Board Replacement: adım 4, 3 resimden 2. Levoit Core 300-RAC Control Board Replacement: adım 4, 3 resimden 3.
      • Lift the control board from the gray plastic cover.
      • Take note of the orientations of the buttons, as that will help during reassembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Mustafa
259 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Petersen Fall 2023 UMass Dartmouth, Team 1-6, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G6
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 88
Her zaman: 1,875
