Ana içeriğe geç
Levoit Core 300-RAC Fan Replacement
Neye ihtiyacın var
    1. Levoit Core 300-RAC Fan Replacement, Air Filter: adım 1, 2 resimden 1. Levoit Core 300-RAC Fan Replacement, Air Filter: adım 1, 2 resimden 2.
      • Make sure your device is turned off and unplugged for safety.
      • Turn the Levoit Core 300-RAC over so the bottom is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Levoit Core 300-RAC Fan Replacement: adım 2, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 2, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 2, 3 resimden 3.
      • Turn the bottom cover counterclockwise and lift it off to remove it.
      • The cover does not "snap" on or off when turned.
      FixBot'a Sor
      Yorum Ekle
    3. Levoit Core 300-RAC Fan Replacement: adım 3, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 3, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 3, 3 resimden 3.
      • Lift the filter straight up and out of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Levoit Core 300-RAC Fan Replacement, Fan: adım 4, 3 resimden 1. Levoit Core 300-RAC Fan Replacement, Fan: adım 4, 3 resimden 2. Levoit Core 300-RAC Fan Replacement, Fan: adım 4, 3 resimden 3.
      • Use a Phillips #2 screwdriver to remove the four screws that secure the gray lid towards the base of the device.
      • Set the screws aside in a safe place.
      FixBot'a Sor
      Yorum Ekle
    2. Levoit Core 300-RAC Fan Replacement: adım 5, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 5, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 5, 3 resimden 3.
      • Use a metal spudger or Jimmy to gently pry between the four white tabs and the white housing to release the outer housing.
      • Gently pulling up on the outer housing can prevent the clips from resetting.
      FixBot'a Sor
      Yorum Ekle
    3. Levoit Core 300-RAC Fan Replacement: adım 6, 2 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 6, 2 resimden 2.
      • Remove the outer white housing and set it to the side.
      • The power cord is fed through a hole in the side of this housing, so it has to sit right next to the device.
      FixBot'a Sor
      Yorum Ekle
    4. Levoit Core 300-RAC Fan Replacement: adım 7, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 7, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 7, 3 resimden 3.
      • Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
      FixBot'a Sor
      Yorum Ekle
    5. Levoit Core 300-RAC Fan Replacement: adım 8, 2 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 8, 2 resimden 2.
      • Remove the four Phillips #2 screws securing the gray face plate.
      FixBot'a Sor
      Yorum Ekle
    6. Levoit Core 300-RAC Fan Replacement: adım 9, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 9, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 9, 3 resimden 3.
      • Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
      • Lift it out.
      FixBot'a Sor
      Yorum Ekle
    7. Levoit Core 300-RAC Fan Replacement: adım 10, 1 resimden 1.
      • Turn your device over so it is upright again.
      FixBot'a Sor
      Yorum Ekle
    8. Levoit Core 300-RAC Fan Replacement: adım 11, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 11, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 11, 3 resimden 3.
      • Insert the Jimmy between the gray grille cover and the top of the device.
      • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
      • Take note of the placement of the tabs, as they are keyed and need to go back in the exact way they came out.
      • Remove the grille cover gently as it is connected by a ribbon cable.
      • Be careful not to put too much strain on the ribbon cable as it may break.
      FixBot'a Sor
      Yorum Ekle
    9. Levoit Core 300-RAC Fan Replacement: adım 12, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 12, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 12, 3 resimden 3.
      • Squeeze the tab on the connector to release the bundled cable from the control board.
      • The connector should come out fairly easily, do not force it. Pulling too hard could damage the connector.
      FixBot'a Sor
      Yorum Ekle
    10. Levoit Core 300-RAC Fan Replacement: adım 13, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 13, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 13, 3 resimden 3.
      • Insert a spudger or Jimmy into the four tabs to release them from holding the outer white housing to the inner black core.
      • Remove the white outer housing.
      FixBot'a Sor
      Yorum Ekle
    11. Levoit Core 300-RAC Fan Replacement: adım 14, 1 resimden 1.
      • Flip your device over again so the fan is facing up.
      FixBot'a Sor
      Yorum Ekle
    12. Levoit Core 300-RAC Fan Replacement: adım 15, 2 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 15, 2 resimden 2.
      • Use a Phillips #2 screwdriver to remove the three screws on the upper portion of the black housing.
      FixBot'a Sor
      Yorum Ekle
    13. Levoit Core 300-RAC Fan Replacement: adım 16, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 16, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 16, 3 resimden 3.
      • Remove the upper portion of the black housing.
      FixBot'a Sor
      Yorum Ekle
    14. Levoit Core 300-RAC Fan Replacement: adım 17, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 17, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 17, 3 resimden 3.
      • Use a 13mm socket wrench with an extension to remove the nut holding the fan in place and remove all hardware from the threaded shaft.
      • There should be a nylon-insert lock nut, a flat washer, and a split ring washer. Set these aside in a safe location.
      FixBot'a Sor
      Yorum Ekle
    15. Levoit Core 300-RAC Fan Replacement: adım 18, 3 resimden 1. Levoit Core 300-RAC Fan Replacement: adım 18, 3 resimden 2. Levoit Core 300-RAC Fan Replacement: adım 18, 3 resimden 3.
      • Lift the fan up and off of the threaded shaft.
      • There is another washer underneath the fan, leave it in place for the replacement fan.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen Carrozza
253 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Petersen Fall 2023 UMass Dartmouth, Team 1-6, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G6
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 42
Son 30 gün: 226
Her zaman: 6,566
