Giriş
Does your Levoit LV-H132 have increased noise when it's switched on, have decreased airflow, have unusual odors, or a visibly clogged filter? If so, use this guide to replace the filter. This repair is necessary so that the air filters are functioning as intended. There are no required tools to access or change the filter. Before starting, make sure the device is unplugged. By the end of this guide your device will work better.
Orient your air purifier so that the control panel faces the bottom and the filter cover faces towards you.
Rotate the filter cover counterclockwise to separate the filter cover from the unit.
2 farklı kişi bu kılavuzu tamamladı.
