Ana içeriğe geç
Lew's Mach Crush Speed Spool Disassembly
Neye ihtiyacın var
Öne Çıkan Belge
    • Refer to the featured document for specific part names and exploded view. Determine whether you have the right-handed or left-handed reel.
  1. Lew's Mach Crush Speed Spool Disassembly, Remove Left-Side Cover: adım 2, 2 resimden 1. Lew's Mach Crush Speed Spool Disassembly, Remove Left-Side Cover: adım 2, 2 resimden 2.
    • Slide switch to 'open' on left side of reel to remove left cover.
  2. Lew's Mach Crush Speed Spool Disassembly, Spool Assembly: adım 3, 1 resimden 1.
    • Remove the palm-side cover, then spool assembly from center frame of reel.
  3. Lew's Mach Crush Speed Spool Disassembly, Lube-Port Screw: adım 4, 1 resimden 1.
    • Remove lube-port screw using small Phillips screwdriver.
  4. Lew's Mach Crush Speed Spool Disassembly, Lube-Port Cover: adım 5, 1 resimden 1.
    • Remove cover off of lube-port.
  5. Lew's Mach Crush Speed Spool Disassembly, Handle Screw: adım 6, 1 resimden 1.
    • Remove screw and handle nut from reel.
  6. Lew's Mach Crush Speed Spool Disassembly, Removal of Handle: adım 7, 1 resimden 1.
    • Remove handle and handle nut retainer.
  7. Lew's Mach Crush Speed Spool Disassembly, Drag-Dial: adım 8, 1 resimden 1.
    • Unscrew star-drag until it is loose, remove it and the handle washer from the shaft.
    • Note: You may have to hold the reels gears in place in order to unscrew the drag, as it will try to spin the gears.
  8. Lew's Mach Crush Speed Spool Disassembly, Exterior Right-Cover Screws: adım 9, 1 resimden 1.
    • Remove three spool cover screws from reel.
  9. Lew's Mach Crush Speed Spool Disassembly, Cap: adım 10, 1 resimden 1.
    • Remove cast control cap.
  10. Lew's Mach Crush Speed Spool Disassembly, Removal of Right-Cover: adım 11, 1 resimden 1.
    • Pry 2 drag spring washers, and 1 click holder washer off to finish removing side cover.
  11. Lew's Mach Crush Speed Spool Disassembly, Removal of Pinion: adım 12, 1 resimden 1.
    • Remove the pinion yoke and 2 pinion yoke springs
  12. Lew's Mach Crush Speed Spool Disassembly, Removal of Main Gear: adım 13, 1 resimden 1.
    • Remove drive gear and accompanying drag and ratchet washers.
  13. Lew's Mach Crush Speed Spool Disassembly, Apply Oil: adım 14, 1 resimden 1.
    • Apply oil to main gear if desired.
  14. Lew's Mach Crush Speed Spool Disassembly, Make any necessary changes: adım 15, 1 resimden 1.
    • At this point, you have disassembled the reel enough to where you can clean parts, remove dust and debris , or replace individual parts
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
Rebecca Welch
250 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 34
Her zaman: 622
