Giriş
The adapter connects the power chord to the printer.
  1. Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
    • Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
    • Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
  4. Firmly push adapter in until you hear a click.
    • Firmly push adapter in until you hear a click.
Sonuç
The adapter should be securely inserted into the back end of the printer and be ready for use.
Bir başkası bu kılavuzu tamamladı.
Raymond
42 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G38
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 713
