Ana içeriğe geç
Lexmark Intuition S505 Ink Cartridges Replacement
    1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: adım 1, 2 resimden 1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: adım 1, 2 resimden 2.
      • Lift the scanning unit, exposing the print head.
      FixBot'a Sor
      Yorum Ekle
    2. Lexmark Intuition S505 Ink Cartridges Replacement: adım 2, 1 resimden 1.
      • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
      FixBot'a Sor
      Yorum Ekle
    3. Lexmark Intuition S505 Ink Cartridges Replacement: adım 3, 1 resimden 1.
      • Lift the frame to expose the ink cartridges.
      FixBot'a Sor
      Yorum Ekle
    4. Lexmark Intuition S505 Ink Cartridges Replacement: adım 4, 1 resimden 1.
      • Push the button located above the designated ink cartridge until it pops out.
      FixBot'a Sor
      Yorum Ekle
    5. Lexmark Intuition S505 Ink Cartridges Replacement: adım 5, 1 resimden 1.
      • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
      FixBot'a Sor
      Yorum Ekle
    6. Lexmark Intuition S505 Ink Cartridges Replacement: adım 6, 2 resimden 1. Lexmark Intuition S505 Ink Cartridges Replacement: adım 6, 2 resimden 2.
      • Close the scanner unit.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Once your ink cartridges are in place, your printer should now print high-quality documents.
3 farklı kişi bu kılavuzu tamamladı.
Omar
132 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G38
4 Üyeler
8 adet Kılavuz yazıldı
3Kılavuz Yorumları
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - Yanıt Paylaş
Merci beaucoup pour tout
Bouzebiba - Yanıt Paylaş
Merci beaucoup pour votre compréhension et bonne journée également bisous 😚
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 3,787
