Ana içeriğe geç
Lexus IS 350 Engine Air Filter Replacement
Neye ihtiyacın var
  1. Lexus IS 350 Engine Air Filter Replacement, Engine Air Filter: adım 1, 2 resimden 1. Lexus IS 350 Engine Air Filter Replacement, Engine Air Filter: adım 1, 2 resimden 2.
    • Pull the hood latch located under the dashboard on the driver’s side to release the hood.
    • Raise the car's hood until the hood struts engage and hold it in the open position.
  2. Lexus IS 350 Engine Air Filter Replacement: adım 2, 1 resimden 1.
    • Locate the engine air filter box, positioned in front and to the side of the engine.
  3. Lexus IS 350 Engine Air Filter Replacement: adım 3, 3 resimden 1. Lexus IS 350 Engine Air Filter Replacement: adım 3, 3 resimden 2. Lexus IS 350 Engine Air Filter Replacement: adım 3, 3 resimden 3.
    • Squeeze the three clips securing the air filter box cover to release them from the cover.
    • Ensure the clips are fully released to avoid damaging them.
    • Remember the orientation of the clips for reassembly.
  4. Lexus IS 350 Engine Air Filter Replacement: adım 4, 3 resimden 1. Lexus IS 350 Engine Air Filter Replacement: adım 4, 3 resimden 2. Lexus IS 350 Engine Air Filter Replacement: adım 4, 3 resimden 3.
    • Lift the cover and remove the engine air filter.
  5. Lexus IS 350 Engine Air Filter Replacement: adım 5, 3 resimden 1. Lexus IS 350 Engine Air Filter Replacement: adım 5, 3 resimden 2. Lexus IS 350 Engine Air Filter Replacement: adım 5, 3 resimden 3.
    • Place the new air filter inside the air filter box.
    • Close the engine air filter box lid and secure the clips.
  6. Lexus IS 350 Engine Air Filter Replacement: adım 6, 1 resimden 1.
    • Close the hood of the car by carefully lowering it and ensuring it is latched properly.
    • Start your car and ensure it runs smoothly. Check for any unusual noises or issues.
Sonuç
You have successfully changed your engine air filter for your Lexus IS350/250!
Bir başkası bu kılavuzu tamamladı.
Chirag Chodha
154 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 66
