Giriş
Replace the pressure gauge in your CNC floor drive pump if the gauge appears to be inaccurate, is malfunctioning or has stopped working all together.
Neye ihtiyacın var
Using a flat head screwdriver, pry up an edge of the gauge cover.
Remove the gauge cover.
Pry up a corner of the gauge face plate.
Use pliers to pull off the gauge face plate.
Use pliers to remove the internal gauge mechanics.
Using pliers, grip the exposed brass piece and unthread the gauge by rotating the gauge counter-clockwise.
Pull the gauge out of its housing.
Remove the O-ring that is at the bottom of the threaded hole that the gauge threaded into.
Place a new O-ring into the hole.
Apply medium-strength Loctite (green, 290) to the threads of the new gauge.
Thread the new gauge into the floor pump by turning it clockwise in its housing.
Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
Allow at least 30 minutes for the thread locker to set.
Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
Bir başkası bu kılavuzu tamamladı.
7 Yorum
i use both gold and silver bracelets because for me, they are both great bracelets to wear;; <a href="https://www.chinamaijin.com/">cnc machining</a>
Its good as your other content : D, appreciate it for posting . <a href="https://www.chinamaijin.com/">cnc machining parts</a>
I feel nice about it and love learning more about this topic. <a href="https://certifiedbourbon.com/product/blu...">blue label for sale</a> I will come to your site to find out more and tell my acquaintances about you.
Nice information and good tips for SEO off-page optimization. I have got good tips to improve SEO off-page Optimization. Thanks for sharing! <a href="https://certifiedbourbon.com/product/pap...>pappy van winkle online</a> please keep it up Maintains!
I was checking continuously this list and I’m impressed! Extremely useful info especially this blog commenting sites list. <a href="https://mushroomlux.com/product/dmt-cart...>purecybin dmt</a> Thank you and best of luck.
