Giriş
Over time, O-rings will wear out and your pump will begin to develop leaks. Some indicators of worn O-rings are low pump resistance while inflating tires, abnormal hissing when pumping, or a pump plunger jam.
Neye ihtiyacın var
Lift the rubber ABS hose cover to expose the ABS hose fitting.
Turn the silver ABS hose fitting counter-clockwise until it fully unthreads.
Remove the ABS hose from the pump.
Bir başkası bu kılavuzu tamamladı.
