Ana içeriğe geç
Lian Li PC-011 Hard Drive Replacement
Neye ihtiyacın var
  1. Lian Li PC-011 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Power off the system using the button on the back of the computer.
    • Remove the power cord from the computer.
  2. Lian Li PC-011 Hard Drive Replacement: adım 2, 3 resimden 1. Lian Li PC-011 Hard Drive Replacement: adım 2, 3 resimden 2. Lian Li PC-011 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove two thumb screws from the back of the case.
    • Slide the top panel backwards.
  3. Lian Li PC-011 Hard Drive Replacement: adım 3, 3 resimden 1. Lian Li PC-011 Hard Drive Replacement: adım 3, 3 resimden 2. Lian Li PC-011 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Remove the remainder of the panels by pulling upwards on them.
  4. Lian Li PC-011 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the two 3 mm Phillips #2 screws from the wire cover.
  5. Lian Li PC-011 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Unplug the two cables from the hard drive.
  6. Lian Li PC-011 Hard Drive Replacement: adım 6, 2 resimden 1. Lian Li PC-011 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Push together the bottom and top tabs and pull the hard drive tray out of the case.
  7. Lian Li PC-011 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove four #2 Phillips screws from the hard drive case in a cross pattern.
  8. Lian Li PC-011 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Replace the old hard drive with the new hard drive.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Suhaib Rahman
470 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Il ni à pas de languette chez moi et sa veut pas sortir
Antho - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 68
Her zaman: 8,223
