Ana içeriğe geç
LifePrint 2x3 Motor-Feeder Replacement
  1. LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: adım 1, 3 resimden 1. LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: adım 1, 3 resimden 2. LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: adım 1, 3 resimden 3.
    • Make sure the top of the Lifeprint is facing upwards displaying the Lifeprint logo.
    • Slide open the top cover and remove the top lid.
  2. LifePrint 2x3 Motor-Feeder Replacement: adım 2, 3 resimden 1. LifePrint 2x3 Motor-Feeder Replacement: adım 2, 3 resimden 2. LifePrint 2x3 Motor-Feeder Replacement: adım 2, 3 resimden 3.
    • Remove the six screws on the outer sides of the device with the Phillips #00 screwdriver.
    • The motor is highlighted in orange.
  3. LifePrint 2x3 Motor-Feeder Replacement: adım 3, 2 resimden 1. LifePrint 2x3 Motor-Feeder Replacement: adım 3, 2 resimden 2.
    • After removing the six screws, gently flip the device over so the bottom cover is facing you.
    • Remove the bottom cover by using the opening pick.
  4. LifePrint 2x3 Motor-Feeder Replacement: adım 4, 3 resimden 1. LifePrint 2x3 Motor-Feeder Replacement: adım 4, 3 resimden 2. LifePrint 2x3 Motor-Feeder Replacement: adım 4, 3 resimden 3.
    • Remove the four screws using the Phillips #00 screwdriver to access the motor and sensor (highlighted in orange).
  5. LifePrint 2x3 Motor-Feeder Replacement: adım 5, 3 resimden 1. LifePrint 2x3 Motor-Feeder Replacement: adım 5, 3 resimden 2. LifePrint 2x3 Motor-Feeder Replacement: adım 5, 3 resimden 3.
    • Remove the component holding the motor and feeder.
    • Using a spudger remove the top piece of the component to get to the motor and feeder.
    • Remove the motor and feeder assembly from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 250
