Ana içeriğe geç
LifePrint 3x4.5 Charging Port Replacement
Neye ihtiyacın var
  1. LifePrint 3x4.5 Charging Port Replacement, Top Cover: adım 1, 1 resimden 1.
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
  2. LifePrint 3x4.5 Charging Port Replacement, Inner Cover: adım 2, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Charging Port Replacement, Charging Port: adım 3, 1 resimden 1.
    • Remove the five Phillips #0 screws from the outer edge of the motherboard indicated by the copper color surrounding the screws' housing.
  4. LifePrint 3x4.5 Charging Port Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a soldering iron to heat up the soldering joints surrounding the port that connects the device to the circuit board.
    • After the solder is heated up use the de-soldering wick to absorb the solder holding the socket to the circuit board .
    • After the solder is removed use the tweezers to remove the port from the circuit board.
Sonuç
Jacqueline Broderick
341 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 UMass Dartmouth, Team S1-G2, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S1G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 415
