Giriş
This guide will show you the steps to replace the battery of the LifeTrak C410. Replacement battery can be found here.
Neye ihtiyacın var
Grasp the body of the watch between your thumb and your index finger.
Slide the band through its clasp.
Remove the four 5.24 mm screws using a Phillips #0 screwdriver.
Remove the back panel.
2 farklı kişi bu kılavuzu tamamladı.
