Ana içeriğe geç
Lifetime 4-Foot Adjustable Table Leg Replacement
Neye ihtiyacın var
  1. Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: adım 1, 3 resimden 1. Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: adım 1, 3 resimden 2. Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: adım 1, 3 resimden 3.
    • Use the 6 mm Flathead screwdriver to remove the four aluminum slotted screws located on the edges of the table.
    • Use a 5/32" Allen Wrench or 19 mm wrench to remove the two stainless 8-18 steel hex screws from the braces of the table.
  2. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 2, 3 resimden 1. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 2, 3 resimden 2. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 2, 3 resimden 3.
    • Clean any glue or adhesive from the braces and hinges before putting it into place.
    • It’s important to clear the screw holes of any material, so that the screws can fit without obstruction.
  3. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 3, 3 resimden 1. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 3, 3 resimden 2. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 3, 3 resimden 3.
    • Align the screw holes of the braces with the new leg by inserting it into the frame.
    • While aligning, make sure the new leg fits into the frame slots.
  4. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 4, 3 resimden 1. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 4, 3 resimden 2. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 4, 3 resimden 3.
    • Place the two stainless steel hex screws inside of the screw holes located on the leg, and secure each screw with your Allen key or wrench.
  5. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 5, 3 resimden 1. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 5, 3 resimden 2. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 5, 3 resimden 3.
    • Screw the four slotted screws back into the frame using a 6 mm flathead screwdriver. Ensure that the entire side where the new leg is being inserted is securely connected to the table once again.
  6. Lifetime 4-Foot Adjustable Table Leg Replacement: adım 6, 1 resimden 1.
    • Test out the table by unfolding it, and setting it up in a standing position.
    • If the leg is not aligned properly, has loose screws, or missing some screws, make the proper adjustments before using it.
Sonuç
Aphason Aberham
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 53
Her zaman: 735
