Ana içeriğe geç
LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming
Neye ihtiyacın var
  1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: adım 1, 3 resimden 1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: adım 1, 3 resimden 2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: adım 1, 3 resimden 3.
    • Use a spudger to gently pry open the remote case to access the battery compartment.
  2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 2, 3 resimden 1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 2, 3 resimden 2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 2, 3 resimden 3.
    • Carefully remove the old battery using a spudger.
  3. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 3, 2 resimden 1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 3, 2 resimden 2.
    • Place the new battery into the compartment securely, noting the orientation of its positive and negative sides.
  4. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 4, 3 resimden 1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 4, 3 resimden 2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 4, 3 resimden 3.
    • Turn the remote upside down and push the cover gently until you hear a click, ensuring it is securely closed.
    • Align the cover to the remote buttons.
  5. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 5, 2 resimden 1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 5, 2 resimden 2.
    • Locate the garage door system on top of the garage and open it.
  6. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 6, 3 resimden 1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 6, 3 resimden 2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 6, 3 resimden 3.
    • Locate the learn button.
    • Press and release the receiver learn button.
    • Within 30 seconds, press and hold remote button.
    • When the opener light flashes, release the remote button which means the programming was successful.
  7. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 7, 1 resimden 1.
    • Press the remote button to ensure it opens and closes the garage door as expected.
    • If the remote does not work, repeat Step 6.
  8. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: adım 8, 1 resimden 1.
    • In case the remote fails and the garage door is closed, use the side-mounted wall remote for emergency access.
    • Press the green light.
Bitiş Çizgisi
Luay Ghabayin
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 106
Her zaman: 2,028
