Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If your light switch has stopped working it may be time to replace it. Follow these steps to replace the light switch in your home.
Neye ihtiyacın var
Locate the breaker box in your house. This is typically either in the garage or the basement.
Open the breaker box.
Turn off the breaker that corresponds to the circuit of the switch that is to be replaced.
Take note of the existing wiring since the new switch will need to be wired in exactly the same configuration.
Unscrew the screws on both sides of the the light switch until the wires may be unhooked. If necessary, these screws may be fully removed to prevent the straightening of the wire loops.
4 farklı kişi bu kılavuzu tamamladı.
