Ana içeriğe geç
Giriş
We will be explaining how to replace the arrow button in the Lightahead DV328 camcorder.
There is only one caution that should be noted when working on this device. Opening the cover, which contains the motherboard underneath, should be done with caution. If it is lifted up too much, the piece will snap in half.
Parçalar
Hiçbir parça belirtilmedi.
  1. Use a spudger to remove the two screw covers. Remove the two Phillips #0 screws. Remove the two Phillips #0 screws.
    • Use a spudger to remove the two screw covers.
    • Remove the two Phillips #0 screws.
  2. Once you are able to lift the cover up, you will then be able to pry off the lens which will allow for the device to open more. Take off the lens cover. Be careful not to pull the device open too much otherwise you will snap it in half since it is made of plastic. Once you have this up, pull up the cover and you will now be able to work on the arrow key button
    • Once you are able to lift the cover up, you will then be able to pry off the lens which will allow for the device to open more.
    • Take off the lens cover. Be careful not to pull the device open too much otherwise you will snap it in half since it is made of plastic.
    • Once you have this up, pull up the cover and you will now be able to work on the arrow key button
  3. Lay the camcorder on its side. The arrow key button is now in full view. There is a small green piece locking in the arrow key button. Once you remove that, the piece will be able to come out. Gently push on the button and it will come out of the device. Replace as needed
    • Lay the camcorder on its side. The arrow key button is now in full view.
    • There is a small green piece locking in the arrow key button. Once you remove that, the piece will be able to come out.
    • Gently push on the button and it will come out of the device. Replace as needed
Sonuç
Alexandra McMurray
355 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team 10-2, Remmell Spring 2016 USF Tampa, Team 10-2, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 66
