Ana içeriğe geç
Lightahead DV328 Strap Replacement
Neye ihtiyacın var
  1. Lightahead DV328 Strap Replacement, Strap: adım 1, 3 resimden 1. Lightahead DV328 Strap Replacement, Strap: adım 1, 3 resimden 2. Lightahead DV328 Strap Replacement, Strap: adım 1, 3 resimden 3.
    • To access the area underneath the camcorder, remove the two pieces covering the screws with a plastic spudger.
    • Remove the two Phillips #2 screws.
    • Gently pull up the cover.
  2. Lightahead DV328 Strap Replacement: adım 2, 3 resimden 1. Lightahead DV328 Strap Replacement: adım 2, 3 resimden 2. Lightahead DV328 Strap Replacement: adım 2, 3 resimden 3.
    • Pull off the lens.
    • Be careful not to pull the cover too far up, otherwise it will snap in half.
    • Inside the device the motherboard and a screw will be visible.
    • Remove the pictured Philips #0 screw to release the strap.
Sonuç
Alexandra McMurray
355 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-2, Remmell Spring 2016 USF Tampa, Team 10-2, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 195
