Ana içeriğe geç
Linear Rail V2/V3 Endstop Install
Neye ihtiyacın var
  1. Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: adım 1, 3 resimden 1. Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: adım 1, 3 resimden 2. Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: adım 1, 3 resimden 3.
    • M3 Sliding T-Nut
    • Slide in the M3 T-Nut toward the middle of the printer
    • M3X12 BHCS & M3 FLAT WASHERS
    • M3x10 FHCS
    • Adjustable Endstop Mount A
    • Adjustable Endstop Mount B
    • Tighten the M3 screw into the T-Nut
  2. Linear Rail V2/V3 Endstop Install, Endstop install: adım 2, 2 resimden 1. Linear Rail V2/V3 Endstop Install, Endstop install: adım 2, 2 resimden 2.
    • Adjust endstop mount until it is square with the Linear rail
    • Remove stock endstop board form Creality mount and Reuse the stock screws to mount the endstop as shown
  3. Linear Rail V2/V3 Endstop Install, Setting endstop position: adım 3, 2 resimden 1. Linear Rail V2/V3 Endstop Install, Setting endstop position: adım 3, 2 resimden 2.
    • Use M3x12 BHCS to adjust the endstop position, so the nozzle tip is even with the front edge of the bed when the end stop is triggered
    • Check the clearance between the motor and the linear adaptor. When the bed is all the way back against the endstop. There should be a 1-2 mm gap when the endstop is triggered.
Sonuç
AJ Pereira
2.735 İtibar
16 adet Kılavuz yazıldı
Ekip
Tiny Machines 3D Tiny Machines 3D üyesi
Community
5 Üyeler
41 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 67
Her zaman: 1,848
